1 - 9 of 9 Posts
Hi all,
I am after a 31.6mm forward seatpost for my 2005 Scott CR1 - carbon or alloy - but can't seem to find one in the market. They all seem to be made only in the 27.2mm diameter size.
I am currently using a Thompson Elite zero off-set seat post, but need to get ~1cm forward to reach my ideal set-up for Triathlons. Please Help!
Thanks so much in advance!
Carbon Fiber = Explode!
What? Everyone makes them in 31.6
Easton, Thomson, Kalloy... everyone uses this size, it's quite popular.
i've heard you can flip around a Thomson setback... so it has a foreward offset.
Thanks guys. The Thompson setback (flipped backwards) sounds like a good option.
My LBS advices against using a shim - says I may break my seat post collar on the carbon frame. How real is that? I would LUV to use the "tricked out" Profile Design FFC. :-D
I doubt that a shim would cause any problems with a CF frame. My old Aegis Aro had a shim for 9 years without any problems. My new Aegis Zaero came with a shim. What CF frame are you worried about?
what's the price diff. between the Prfile and the Thomson??? I think the Masterpiece runs $140 msrp... I like the looks of the Thomson on a non TT/Tri bike... But if your bike is aero you might as well go aero all they around.
1 - 9 of 9 Posts
