Recipe:
Buy:
1.) White Lightening - Clean Streak, $16.00
2.) gallon size metal can WD-40, $16.00
3.) Tri-Flow, $8.00
4.) canned air, $2.00
5.) translucent 1 quart container/ lid, $3.00
I had a pair of Shimano Brifters with the right / rear frozen after sitting in the garage all winter. This has happened a few time before.
Step 1: Remove rubber hoods and saturate the internal shifter gears with WL Clean Streak.
Step 2: soak the brifters for 24 hours completely submerged in WD-40 in the translucent 1 quart container with lid (sold where they sell the mineral spirits at Home Depot), and agitate vigorously as many times as possible.
Step 3: Inject a lot of canned air (like you use to clean computers) to purge the now softened old grease out of the gears.
Step 4: Dry them in the sun for a few hours
Step 5: Re-lubricate the gears with a ton of Tri-Flow. Dry and replace hoods.
Done!
They now are shifting like new - amazing. I have gotten rid of 3-4 pairs of brifters over the years that I thought were shot, that I know would have been fine if I had done this method. Oh well, hindsight is always 20/20.
From now on all brifters will get this treatment when they start shifting poorly.
Side note; before I filtered the WD-40 back into the can, I soaked about 8 of my extra chains that I had previously cleaned these with gasoline (bad idea, because of the horrible smell - that seems to last permanently). I was amazed at how much gunk and dirt came off this time around. And, I actually like the smell of WD-40.
I let the quart container sit for a day after, and the gunk/ old grease sank the the bottom. I was able to pour almost all of the WD-40 back into the can.
Whatever WD-40 made from, ( What's Inside WD-40? Superlube's Secret Sauce ) the gallon size works perfectly for this "repair"! I realize that I put my stable of brifter equipped bikes through torture in storing them year-round in an unconditioned, separated garage/ shed (with high heat and cold that Maryland brings).
Buy:
3.) Tri-Flow, $8.00
Done!
