1 - 5 of 5 Posts
imbasilical moreon
Scotty ... ponder this:
4.8 lbs / hp ... 0-60 in 3.1 ... way less than $7 mil ...
I crave theze carz ... they are the total schnizzle ... if you don't agree, u r just a fewel or ignRrnt .. or both ...
The new CSR is the ultimate Seven, with chassis and drivetrain enhancements that produce the highest performance levels ever in a Seven. The new model benefits from the introduction of new F1-style inboard front suspension, full independent rear suspension and aerodynamic enhancements. With available Cosworth Duratec 2.3 power, the new car does 0-60 in 3.1 with a top speed of 155 mph. The CSR represents the most dramatic redesign of the Seven ever, with over 75% new parts and incredible performance packaged in the familiar Seven envelope.
MSRP $44,000.00 (Price for complete kit - less engine & transmission.)
Construction:
Tubular space frame with aluminum honeycomb cockpit side impact protection.
Aluminum body panels with composite nose cone and wings.
Dimensions:
Wheelbase: 2,315mm (91.1in), Front track: 1,505mm (50.0in), Rear track: 1,465mm(59.3in),
Overall length: 3,300mm (129.9in), Overall width: 1,685mm (66.3in), Height (hood up): 1,140mm (44.9in),
Weight (approx.): 600kg (1320lb), Ground clearance: 100mm (3.9in), Turning circle: 11m (36ft)
Recommended Drivetrain:
Cosworth 260-hp 2.3l Ford Duratec with Caterham close ratio six-speed transmission.
(See U.S. Engine Program section for details.)
- Inboard Double Wishbone Front Suspension with Anti-Roll Bar, More info...
- Fully Independent Rear Suspension with Anti-Roll Bar, More info...
- 10" Ventilated 4-pot Front and 10" Rear Disc Brakes,
- 10-spoke Caterham Wheels with Avon CR500 Tires, 15"x6.5" with 195/45 front, 15"x9" with 245/40 rear More info...
- R500 Style Roll-Over Bar
- Seven Grille More info...
- Aluminum Radiator
- Aeroscreen
- Boot Cover
- Cloth Adjustable Seats
- 4-point Seat Belts
- Momo Steering Wheel More info...
- Aluminum Body with Choice of Standard Fiberglass Colors (BRG, Yellow, Red, Black) Color samples ...
Option Packs
- Roadsport Pack: Top and Side Curtains, Windscreen in Lieu of Aeroscreen, Wipers, and Fresh-Air-Heater ($1890.00)
Paint
- In Standard Nonmetallic Color (Caterham Green, Red, Yellow, Orange, Blue, Black) ($1325.00)
- In Standard Metallic Color (Atomic Bronze, Titanium Sliver, Platinum Silver, Viper Blue, Kingfisher Blue) ($1834.00)
- Nonstandard Nonmetallic Color (from $1492.00)
- Nonstandard Metallic Color (from $2000)
- Bonnet Stripe (from $292.00)
- Nose Stripe (from $125.00)
Interior
- Adjustable Leather Bucket Seats ($583.00)
- Composite Race Bucket Seats ($417.00)
- Carbon/Alcantara Seats ($2000.00)
- Carbon-Fiber Dash (Standard Dash Only) ($492.00)
- Integrated Dash/Lowered Floor ($2159.00) More info...
Suspension
- Aero Wishbones ($834.00)
Differential
- Limited Slip Differential ($1250.00)
Wheels and Tires
- Spare Tire w/Holder and Jack Kit ($583.00)
Other Factory Options
- Quick-Release Steering Column ($347.20)
- Blackpack: Black Headlamps, Windscreen Frame, Exhaust Guard, Carbon-Fiber Wing/Sill Protectors ($467.00)
- Stack Dash (Standard Dash Only) ($834.00)
- Push-Button Start ($83.00)
- Race Filler Cap ($133.00)
- Carbon-Fiber Front Cycle Wings ($667.00)
- FIA roll-over bar ($292.00)
- Battery Master Switch (Fitted) ($250.00)
Dealer-Supplied Options
- Carbon-Fiber Rear Wing Protectors ($216.80)
- Carbon Fiber Sill Protectors (2) ($141.60)
- Carbon-Fiber Indicator Pods (2) ($103.96)
- Tonneau Cover (from $277.43)
- Lowered Floor (One Side) ($455.00)
- Hood Bag ($109.20)
- Heat Insulation Kit ($91.00)
- Luggage Rack ($134.40)
- Perspex Wind Deflector Kit ($137.20)
- Fresh-Air Heater w/Cable ($539.00)
- Aeroscreen Kit w/Mirrors, Fiberglass ($708.75)
- Aeroscreen Kit w/Mirrors, Carbon Fiber ($1088.00)
- Aluminum Honeycomb Fuel Tank Protection ($315.96)
- Aluminum Honeycomb Floor Protection (One Side) ($234.25)
- Windscreen and Wipers ($1289.25)
- Dust Cover ($114.38)
- Weatherproof Car Cover ($413.00)
NO FANCY ST'RRIN WHEELS - just a clean Momo ......
Video of a 7 running down a Ferarri F40 ... it's prolly a Superlight ... only 180hp
wut?
Nice... I'd still rather have an F1 car. I'd sell it for $1,000,000 and buy 22 of these thing.
imbasilical moreon
yes, at 1.7 lbs/hp an F1 is awsome.....
but these are affordable and they really do run well on the track ...
my bro-in-law runs 911s (street modified) and he says these things
will eat his lunch ... and that's at 180 hp
a buddy who was Nat'l Champ in Spec Racers ('05) considers these
a notch up from what he races ...
and the new Super 7, with 260hp, is going to be way awsome
.... did you play the video? ...
1 - 5 of 5 Posts
