1 - 2 of 2 Posts
QUAILMAN85749
I am thinking I need to upgrade the front deraileur to a 10 sp since everything else in the drive train (Ultegra) is 10 speed. Shifting gets done but it is cranky when the chain is in the larger cogs (smaller gears). When the chain is on the outside cogs, it works fine. Obviously the cage is just a tad wider on the 8-speed to accomodate the wider chain. Thank you for your replies.
waterproof*
sounds like you already have the answer; the 8 "works" but it's not to your satisfaction.
get a 10. 105 should work fine if you're saving bucks.
1 - 2 of 2 Posts
