An aluminum Vitus 979? I have one that runs 8 speed. If you want to run 8 speed, you'll need a 130 rear wheel. There are no problems stretching a 979 to 130. The stays are quite flexible.Mr Bentwrench said:
In answer to your shifting question, yes you can use 8 speed shifters to shift 7 speed. The spacing between cogs on 8 vs 7 is almost indentical. You just don't use the extra click. I've done it many times
