1 - 4 of 4 Posts
The last time i asked about the difference between 9 and 10 speed FSA carbon crankset.
Now is the follow-up question:
If I have a 9 speed FSA Crankset, would it work with my 10 speed record drivetrain? Would be able to ship perfectly the 10 gears and 2 rings in front?
Yes and depends...
It will work with your 10 spd drivetrain. Will all cogs be useable from both chainrings.... depends on how long your chainline is. If your chainline is relatively short, then no, there will be some high cogs that will cause your chain to ub on the outer chainring when you're in the 34 up front. Should you be in those combos anyway... probably not ;-)
1 - 4 of 4 Posts
