A bike chain is based on English inch measurements. The chain pitch (distance between the pins) is .500 inch. This dimension must be very accurate and the same between brands, but if you measure between the rollers, using the internal tips of calipers, you'll find substantial differences between brands. A Campy chain may measure 5.200 inches when new, but Shimano or KMC chains can measure 5.210-5.215 inches, due to differences in the roller OD, ID and the OD of the bushing formed into the inner side plates.
If this measurement is used to evaluate chain wear, you're mixing both the change in pitch with roller wear. When the true elongation of a chain (measured properly between the pin centerlines) reaches .5%, the wear between any two rollers can be as great as the elongation, measured over such a short length. Your caliper reading may suggest an elongation of 1%, when it's only .5%. This is why most chain checkers are so inaccurate. They may show a new Campy chain to have zero wear, but a new Shimano or KMC chain to be worn by .25%. Future reading will add both this false wear and roller wear to the true elongation.
Different chain brans also wear differently. Campy chain may have .15% elongation after 6,000 miles of use, but the rollers will be extremely worn at that point, with a space between the rollers of .240 inch (compared to .200 when new). The chain should have been tossed before that mileage was reached. A Shimano or KMC chain is likely to reach .5% elongation after only 3-4,000 miles, but roller wear at a given mileage may be similar to a Campy chain.
