I think I read this on sheldon brown once, but somewhere he suggested that its possible with any standard quick release axle to cut off both ends of the axle so that they are flush with the lock washer (essentially removing the part of the axle that normally sits in the dropouts) and you should have enough amount of play to tension a chain in a vert. dropout frame.
Assuming your QR skewer is strong enough (i'd get the through-axle bolt-on things) it sounds like it would work. Any thoughts, anyone ever try this?
