I have a set of 99 Record hubs (the kind with the slide on cones). The Campy maintenance manual (http://www.campagnolo.com/pdf/177-FI Mozzi Ant 2000.pdf) page 15 says to adjust the hub such that "the axel slides easily and without play". I've read elsewhere (Park Tools and Sheldon) that you want a little bit of play which will then be eliminated when the wheel is put back into the drop outs and the quick release tightened. Any thoughts?
