Have you try giving it more slack for the brake cable? There is a screw which holds the cable on the cantilever arm. After you unhook the brakes, loosen it, after you get your wheel on, adjust how much gap you want between brake pad and rim by holding it with one hand and tighten the screw back up with the other hand.
