1 - 7 of 7 Posts
rock n rolling resistance
I hear plastic eyewear frames can be adjusted/manipulated after heating them... mainly in hot sand (supposedly opticians use this method) but some say in hot salt or even hairdryer and hot tap water.
I have a number of ill-fitting sunglasses (slides down from vibration, sweat, grease). With my big round noggins makes it hard to find glasses that fit securely. Just little bit of bend here and there I'd have some perfectly fitting nice sunglasses. Has any of you actually tried this or know how to do it?
I prefer hot water - heat in microwave and let the part of the frame sit in the water for about 30 seconds and then gently bend it the way you want. There is a limit to how much you can do but it will definitely improve fit a noticeable amount.
I'm gonna try this out with Performance pair first then move up to Tifosi, Smith then Rudys.
Is this safe to try on good sunglasses?
disgruntled pigskin fan
If you know what you're doing, yes. I do it all the time in clinic on regular glasses.
1 - 7 of 7 Posts
