There is a closeout at the LBS for a 2009 FSA SL-K Carbon Crankset (53/39). However, when I did a quick internet search for reviews, I found that many users had dismal experiences. But I’m wondering if a lot of the problems were due to installation error or just dumb luck. I don’t understand how cranks that retail for over $400 can have such crappy reviews. I tend to trust RBR advice over disgruntled rants, so please chime in on your experiences.
I’d like to buy the crankset, but I don’t want to have to deal with a bunch of problems later on.
Note: I searched “FSA SL-K Carbon Crankset” to look for reviews. The review ratings seem to vary greatly from compact to standard, and light, and BB30. Are all the variations of the FSA SL-K crankset that different?
Below are some excerpts from various reviewers:
1. This unit requires real care during when doing tuneups or quick adjustments or you may find chain resting between the gears and getting you nowhere. In some cases the wavy washer makes noise when it loses its shape.
2. After 3hr riding the pedal piece got totally off the right arm. And there is a movement at te bottom of the left arm.
3. The cranks vary in weight by as much as 40-50 grams per set. Often spiders and rings were not true.(however after sampling a a group of the SL-K Light, that does seem to be vastly improved). Rings also could use some improvement in their shifting quality and a reduction in q-factor would be nice.
4. after first 6 months cranks were great after that notice alot of creaking lbs took them apart cleaned re-lubed still did the samething 2 months later while riding left crank arm split and pedal came out…
5. After about 2500 mls, I noticed friction in the crank. Took it to a LBS. The left bearing was about to freeze, the right was very gritty…3 wks ago the cranks started to make noise when standing and mashing hard. At home I noticed the spring wavy washer wasn't there any more on the left side.
6. Everything comes loose. Within miles. And with loctite.
7. chain slip with downshifting - basically if you cannot downshift safely the product is worthless
8. …Short life span.
9. These cranks should be recalled. No question about it. Terrible equipment. I couldn't get any cadence, and every effort seemed like it was restricted. Like riding on a wind trainer with the resistance on full.
10. Don't get this crank unless you want to get a new crank every two years.
http://www.bicycling.com/gear/detail/0,7989,s1-17-107-607-0,00.html
http://fairwheelbikes.com/forum/viewtopic.php?f=77&t=5991
http://www.roadbikereview.com/cat/drivetrain/cranksets/fsa/PRD_335458_2491crx.aspx
