1 - 5 of 5 Posts
I'm having a hard time trying to fit an aero bar in an indoor bike that has a non-standard clamp size (it's 32.46 instead of 26.0 or 31.8). I believe replacing the handlebar is not an option for the Cycleops 400 Pro.
I wonder if someone knows a place that could customize an aero bar to fit that clamp size.
Cheers!
Cranky Old Bastard
It's only .66mm (.026") larger than 31.8, you can get some sheet metal and make a shim.
A machine shop will make anything you want.
Why not just get a piece of 1/8" steel plate and drill a couple of holes in it, you may need longer screws.
Don't hurt yourself if you lose control on the aerobars in the corners.
Note: In this universe it is virtually impossible to make a clamp bigger with shims.
Cranky Old Bastard
I wonder where he got that 32.46 figure. Measuring the bars or the open clamp?
It's only a trainer and only a tiny difference, I'd get some cheap alloy 31.8 bars and tighten it down.
1 - 5 of 5 Posts
