Why would rider weight have anything to do with it? If anything, since smaller riders typically have a higher ratio of aerodynamic drag to power, aerodynamic equipment should be more significant for smaller riders.CC09 said:I heard recently that aero spokes are significantly less effective for riders under 150-160 lbs?
is this true?
Because of Bernoulli's Mass Flow Uncertainty Principle: fluids in flow have some uncertainty about the mass of the body passing through them. They tend to assume that large bodies, i.e. humans, are muy massive, but are not completely certain. Thus the uncertainty. When they find out that the body isn't as massive as they thought, they find that a real drag.Mark McM said:Why would rider weight have anything to do with it? If anything, since smaller riders typically have a higher ratio of aerodynamic drag to power, aerodynamic equipment should be more significant for smaller riders.
Where do you get this stuff?! No (or at least not too much) offense, but you seem to have the knack for coming up with some strange ones! Wherever it was you heard this, I suggest you not go back there, as whoever said it is nucking futs. Unless of course, they were saying something COMPLETELY different and you just misunderstood itCC09 said:I heard recently that aero spokes are significantly less effective for riders under 150-160 lbs? is this true?
