I think that the difference between any two aero wheels is typically less than 0.1 mph. If that somehow makes a difference to you, then you might want to do a lot of detailed research. That said, if you are a good rider enough that 0.1 mph makes a meaningful difference to you, maybe you should let your sponsor and your team mechanic sort it outbakstreet said:Where is a good place to look at aero wheelset comparisons? I'm looking at the HED Jet 60's and the Rolf TdF58's and would like to see how they stack up. What do you think?
You make it sound as though 0.1 mph is a trivial difference. That may be true for just riding around, but for timed events, 0.1 mph translates to 15 seconds for a 1 hour 40 km rider. I know a lot of amateurs who care about differences like that. Usually that's worth a few places in amateur events, and often makes the difference between first and second in State Championships.Kerry Irons said:IThat said, if you are a good rider enough that 0.1 mph makes a meaningful difference to you, maybe you should let your sponsor and your team mechanic sort it out![]()
According to Rolf the Vigor SL is more aero than the TdF58: http://www.rolfprima.com/techinfo_aero_results.phpbakstreet said:Where is a good place to look at aero wheelset comparisons? I'm looking at the HED Jet 60's and the Rolf TdF58's and would like to see how they stack up. What do you think?
My point was NOT that you couldn't place a little higher with a slightly faster wheel, because obviously you can. My point was that each of us has to determine whether that MEANS anythingasgelle said:You make it sound as though 0.1 mph is a trivial difference. That may be true for just riding around, but for timed events, 0.1 mph translates to 15 seconds for a 1 hour 40 km rider. I know a lot of amateurs who care about differences like that. Usually that's worth a few places in amateur events, and often makes the difference between first and second in State Championships.
If someone is going to buy a new set of wheels, I don't see why they should ignore the potential benefits that come with lower drag. That doesn't mean a lower drag number from one test should be the sole consideration, but neither should it be ignored alltogether.
