OMG...the roads are just crumbling around here.....they are literally a mosaic of broken bits of asphalt after the winter we had. It is exhausting to ride on! The center line seems to be in the best shape, but that is NOT the best place to ride most of the time...
I am starting to worry about getting a front tire into a crack or hitting a hole (un-avoidable sometimes) at any rate of speed.
Yesterday it was so rough, that when I finished, I checked my headset (threaded) and it was a bit loose, the two nuts were not jammed tight against each other they had vibrated LOOSE!!!
note to self: service headset Monday
When you hit a bit of new of un-damaged road it is like you died and went to heaven.....then the new pavement goes away.....back to reality....Honestly, I thought my fillings in my back teeth where going to rattle loose.
