Is there any dfference in using an Aluminum or Carbon seatpost other than the slight weight savings . This will be used on an all carbon Tarmac frame. I thought I read once that carbon seatposts were hype,no difference in ride quality.
This is complete BS. You can't make absolute statements like this. CF can be stiff or noodly, just like any metal product can.psi_co said:The carbon post will flex a little side-to-side, a metal-post won´t.
That´s why I said " it depends on the post".alienator said:This is complete BS. You can't make absolute statements like this. CF can be stiff or noodly, just like any metal product can.
Unless you get a suspension post, your best bet would be to play with the air pressure in your tires to get a better ride...or change tire sizes so you can run lower pressure.
Exactly which manufacturers recommend replacing their CF posts every year? I'd say that's a load of crap, because it makes no sense to do so. The Alien failure was either a manufacturing flaw or a design flaw.mmercier said:I used to use CF posts, but now I use Al exclusively. I had the CF Alien Aero post on my race bike, but when I changed saddles it was a serious PITA to adjust the clamp. So, I got rid of the damn thing and went with an old-school, reliable Thomson Masterpiece. I can discern no difference in ride quality and the Thomson is infinitely more user friendly. Also, a friend of mine, last year's national master's RR champion, who rides about 13K a year, experienced a catastrophic failure of her CF post clamp. The clamp broke where it attaches to the post. As a result, her saddle simply fell to the pavement during a training ride. She weighs about 100 lbs. Luckily she wasn't hurt. It was an CF Alien post. She too now eschews all CF posts. She now uses a Thomson. Additionally, many CF post manufacturers recommend you replace their posts every year.
I used USE alien ti and cf posts on my Giant TCR. if there was a difference, it was a pretty small one. on my ti frame, I definitely can't tell any difference between ti and aluminum posts. on a really stiff frame, though, I imagine that Specialized post with the inserts would make a noticeable difference, all else equal.jhenry4 said:i recently replaced an old Al seatpost on a cannondale CAAD 2.8 with a specialized pave seatpost with the zert insert. this made a huge difference in comfort on a stiff frame. on a frame that has comfort features built in like the specialized tarmac this will make less of a difference, however if your body is more sensitive to vibration every little bit helps.
