This is interesting -
The Robot Bicycle Wheel Building Revolution - BikeRadar
Make sure you check out the seven photos.
The vid is great. Love their "spoke twist eliminators" and spoke stressers.Thanks for posting. Interesting article. About 30+ years ago there was an article about Wheelsmith, the guys out of Palo Alto, using a machine wheel builder but slowing down the rate of build significantly and that is how they made the majority of their wheels back then.
I think a lacing machine (and a hub spoking machine if they exist) would be far more interesting than a tension/true machine. I just can't imagine how one would work.is there a video somewhere of the wheel lacing machine? That would be interesting to see.
All those can be more accurately and quickly assessed by machine. If you want to check up on the first machine, use a second to QC it's output. The only reason to use humans is because you don't have the volume and budget to automate it.The best wheels, even machine built wheels have a post-build inspection done with humans checking and recording spoke tension, runnout and truness. ...
