Am I correct in thinking that a 1 degree increase in seat tube angle approximately equates to a 1cm increase in reach if top tube length is the same, assuming the saddle is set the same distance behind the bottom bracket?
Current bike has straight 73/73 angles, 57cm effective top tube and 100mm stem.
I'm looking at a frameset that has a 74.5 degree seatube, 72 degree headtube, and a 53.5cm effective top tube. Seems like a massive decrease in top tube length, but if the extra 1.5 degrees on the seat tube means I can think of the top tube as equivalent to 55cm, I should be able to use a 120mm stem and get about the same reach, right?
Assuming this is correct, what sort of differences could I expect in handling from a bike with such significantly different geometry? Head tube length and chain stay length are identical.
