1 - 4 of 4 Posts
Out riding the last week and have been noticing an annoying popping noise when i stand and sprint/climb in the drops. I was wondering what you all think. Me being tech dumb I would have probably over tightened a bolt?
Greatly Appreciated
FeltS22TimeMan
I had a similar sounding issue on a new ride of mine. It only happened when I was hammerin' out of the saddle. Took it in and it turned out to be the BB (FSA, external) which was cross-threaded by the factory. I needed a whole new crank/BB/assembly.
I had a similar problem and thought my carbon fork was going to explode. Then one day I forgot my water bottle and the noise was gone...it ended up being my bottle rocking around. Sounds stupid but that will make a clunking sound
· Fini les ecrase-"manets"!
Check the faceplate bolts on your stem--the ones that hold the bars in.
If they're even slightly loose, the bars will move, usually generating a heck of a POP or CRACK sound. I thought I'd broken my steerer tube once, but it turned out to be my bars shifting around. Tightened the bolts and it stopped.
1 - 4 of 4 Posts
