The frame came to me via an Internet friend, and it is in rather good cosmetic shape. Just the usual scrapes in an amount that will make it less stressful to take the finished bike on the road.
It is made with Reynolds 753, a grade of steel I've yet to ride (although my unmarked 92 Gazelle is purportedly of same material, according to the seller Mr. Stone of the UK).
The Look is a 62cm cc, with a 59cm top tube and 42cm chain stays. The wheel base will likely end up being a relaxed 102.5cm. 126mm rear spacing, English threads throughout, and the usual 27.2mm seat tube ID.
The year is probably mid eighties. Did Look build this frame or, as have been suggested on the Web, some unconfirmed frame maker got the contract? Who knows?
Anyway, enough chatter:
I started out scrubbing the frame and fork with Simple Green. After drying I removed many shallow blemishes with Turtle white polishing compound and wax .
The English threaded BB shell was in good shape, with the taps just needed for general cleaning of old framesaver and cheese like grease deposits.
Then I cut the faces to remove a few little dings and again mostly just to clean things up.
The fork got the same treatment. Here the crown race under the knife..
..and the threads
..and the threads
