kpcw said:
I still do not know if I want to talk/discuss tv's with you...do you have a Samsung tv set or not???
Er uh um, 3 sets failing? Sumptins wrong etc.
What tv set are you currently using? Model number? Make, the whole 411 dude.
Something wrong?.... ya think?....
The odds of getting a bad set are reasonable....two pretty low but 3?....but then again...SOMEONE has to be the 1/4 of .05%....normally...that's ME.
Considering all the problems have been totally different..... sigh.....
I purchased a Vizio, L32 HDTV and set it up through an attic mounted, 55 inch boom antenna with a rotor and a Radio Shack 15-2507 Antenna mounted High-gain signal amplifier (30dB adjustable) I run the coax through surge protection. I need to split the coax into 3 for the NTSC input, the DTV input, and a third for the stereo FM signal. I am rural (53579) and the stations I am getting are at least 25 miles away. I am running the coax through an A,B,C switch (manual)for now and all seems to be working just fine, I have good reception and very little interference. I have had 3 problems so far with sets failing, 2 Polaroid, and now this Visio. The first, the HDTV tuner just flat out quit acquiring the signal after less than 24 hours, the second , well it popped, and set up a high pitch squeal and died after 19 days. I replaced with the Vizio and set it up and less than 8 hours later it developed vertcal stripes on the right side of the screen. They are replacing the set but I am so tired of this. Is there something that I could be doing on the antenna side of this that could be causing the problems?????
Would I be better off with a splitter than an A,B,C switch if I could?
Could the signal through the amplifier be too strong? I changed amps and surge protection between set 1 and 2...and I have the amp set to the lowest gain (20dB I believe)
