I have gone through 5 PAIRS in 3 days. This time the faliure caused me to go down.
4 days ago I put in a new latex Vittoria tube. I pumped the wheel to 105psi and went for a ride. at the 22 mile mark, it went flat. So I patched it.
Added air went 10 feet and another flat.
So I get home patch it. I got to 40 psi flat! the tubes are all pinch flating within 5 mm of the valve stem. So first I thought I was rushing or making a mistake. So I tired a new tube, even added talc powder. I carefully put the slighty inflated tube in. 30 psi flat, with in the same area.
So I took the wheel to the LBS with a new tube. They installed it, 42 pis, flat!
So we added a new tube, changed out the rim tape, flat @ 30psi.
So we stuck in a regular tube and it was fine. So yesterday I add another new tube, but this time I moved the Michelin to the rear and the Vittoria up front. The Michelin inflated fine. This time the Vittoira was fine also.
So this morning I go for a ride and I turn a corner and down I went. Guess what? A flat tube in the same spot. I just called Nasbar to return 4 tubes that I think are defective. I sent an e-mail off to Vittoira USA to see what's up!
Anyone else having any issues? Never any issues with the Michelin tubes. They are even thicker too.
Also do ALL latex tubes loose air very fast? It seems like once they go flat, they loose air very, very fast!
Yes MODS, I posted in the wrong forum, sorry!
