1 - 4 of 4 Posts
Just bought a Felt DA frame and know that it REQUIRES 4mm derailleur cable housing. I'm building it up with Campy Record and was going to just get the Ergopower cable set, but wanted to be sure the derailleur cable housing in that set is 4mm. Thanks in advance
Adorable Furry Hombre
IIRC, Campy uses 4.5mm der housing, IIRC.
4.8mm
Not that it matters, but the shift cable housing is 4.8mm. You can use generic 5mm or Shimano 4mm housinf if you choose, just be sure the ferrules that you buy fit the housing. The OD of the ferrules will fit Campy shift levers.
1 - 4 of 4 Posts
