Got out of a test ride on Sunday afternoon. Hot in the valley but fortunately the temperature inversion that's been hanging around most of the last month is gone. Back to the normal 15F cooler temps once you start climbing up in the Santa Cruz mtns.
Rear brake is working great with the new pads and re-aligned caliper, totally silent. Also, I think I'm liking the 10mm longer wheelbase, front tire seems to stay planted easier on steep 30% ramps on the dirt trails. I think my RD is also working a little better with the new 11-45 cassette. I had been getting some chain skipping in the lower gears under heavy load but at least on a few tests, that seems to have gone. With the axle/cassette moved back, now the upper jockey wheel sits just in front of the large cog instead of right in line with the diameter. Maybe that bit of gap helps, time will tell.
Update: And yes, the longer wheel base, along with re-indexing the RD, seems to have cured the ghost shifting issues. Moving the axle back gave 10mm more horizontal separation between the jockey wheel and the big cog. I guess when it comes to shifting, vertical separation via the B-tension screw is the same as horizontal separation. In other words, a gap is a gap, makes no difference if up-down or front-back. I've been working on climbing a 50% ramp on one of the local trails. Needs hero dirt conditions to make it with the 40C touring tires on the bike.
View from the Grizzly Flat parking area on Hwy. 35 looking SW towards the area of the CZU fire complex. Just a bit of haze in the air:
