1 - 3 of 3 Posts
I have a set of Dura-Ace (9 speed) wheels from 2001 that have probably 20,000 miles on them. The bearings are new.have recently been replaced.
I noticed when I hold the freewheel in one hand and the axle with in the other and spin it, there is a rough feel (rubbing a bit).
The wheel does spin for awhile before stopping but in comparison when I spin an Easton wheel it feels much smoother and spins much longer.
So I know there is a problem. Any idea what it is and can it be repaired? I'm thinking one possibility is the free wheel hub - someone mentioned the hub itself.
Thanks in advance.
Thanks in advance.
Assuming you are holding it but the axle and not the freehub itself, its not the freehub. Older hubs are a pretty simple thing. There are cones attached to an axle. The cones ride on a set of ball bearings in the hub. On the other side is a race. Any one of those 3 could be the problem. It is likley repairable. Its not difficult to dissemble it yourself and have a look
I just went out and held the axle and spun it - it is definitely rubbing. I'll take it apart and see if I can spot the problem. Thanks..
1 - 3 of 3 Posts
