1 - 7 of 7 Posts
I have been riding Arione's for a bit and recently noticed (after some numbing issues) that the shell on both of them has cracked. This seems to be an ongoing problem with Arione's.
I like being able to use the saddle in multiple positions and the ease that you can slide around on it a bit. I've never been a fan of one position saddles. I wouldn't mind adding a cutout as it seems that it cannot hurt to have it.
Any recommendations on a saddle that would be similar in feel and features to the Arione but a little less prone to cracking?
Thanks,
Zach
Colorado Cyclist has a Arione knock-off, it's called a Apex ($29.99). It has the same shape, but without the WingFlex. It has an anatomic nose relief. I tried one but my rear did not agree with the foam rubber cover. That's not saying it won't work for you. Bike Nashbar also has a couple of saddles with the extended length. Neuvation has some saddles similar to the Arione, with a guarantee. All those saddles are made by Velo.
I have a Regal mounted on my old Colnago that works well. It's long, but wide. I don't know how it would work for numbness.
There is also the Fizik Gobi, Nashbar has factory seconds for around $90.00.
Or maybe you need to get away from that design. Arione's tend to be on the soft side. You might need a firmer saddle.
· Shirtcocker
Thanks,
Zach
SLR is pretty similar shape, but not as long as the Arione.
I'll check into the SLR - I didn't realize they could be multi-positional. I don't think the Arione is that long - most of the extended length seems to be at the very back, which is unusable unless you have a crazy position...
Zach
· Shirtcocker
Zach
Didn't read your post that close...the SLR isn't really that multi-positional IMO...not long enough, but the shape is similar. You might look into a Flite...they tend to be longer.
try out the toupe 143. the perfect saddle. My airone was pretty awesome all year last year. but about 6 weeks into this spring riding season, it got very uncomfortable. The shop near me loaned me the toupe, I road it twice for 2 and 3 hours. Its awesome.
Same saddle at Price Point for $5 less
Price Point has the exact same saddle as Colorado Cyclist for $24.98, its called the Sonic
:thumbsup:
1 - 7 of 7 Posts
