Claimed weights are 1619 grams and 1740 grams respectively for the 38mm and 50mm rim depths.
Claimed weights are 1619 grams and 1740 grams respectively for the 38mm and 50mm rim depths.​
Atomik Carbon is branching out into the realm of disc brake-compatible road wheels. After making its paved debut with three tubeless-ready carbon clincher wheels, they now have 38mm and 50mm disc models that are also tubeless ready.
The new Atomik Carbon road disc wheels are made with a proprietary prepreg and layup process featuring Japanese Toray composite technology. It's designed to deliver precise handling and power transfer. All wheels are six-bolt disc compatible and directionally drilled, featuring Sandvik stainless steel aero-bladed spokes laced to Atomik four-pawl hubs with 24 points of engagement featuring a full compliment of stainless EZO bearings.
The new Atomik Carbon road disc wheels are made with a proprietary prepreg and layup process featuring Japanese Toray composite technology.​
Claimed weights are 1619 grams and 1740 grams respectively for the 38mm and 50mm rim depths. Inner diameter is 17mm and spoke counts are 18/24 front and rear.
Atomik Carbon Road Disc wheels ship pre-taped for tubeless setup and include one extra spoke of each spoke length, a 10-speed spacer, tubeless valves and skewers/axles based on configuration. They are backed by a one-year no-questions-asked replacement warranty covering up to two rims for the original owner, and are available now via Atomik Carbon's consumer direct program at AtomikCarbon.com for an MSRP of $1549.
