'87 Specialized 600sis
Probably been asked a lot but if you will:
What is the trouble shooting sequence to address the problem of the chain slipping from a larger to smaller rear ring while climbing. I know I need a new bike but in the meantime... I get sooo frustrated going up hill.
I've tried the lube under the bottom bracket to solve 'frame-flex' shifting but still have problem.
Are there derailleur adjustments that are usual to make (I have not done that) or some part to try replacing? Is it hopeless??
I'll take it to the LBS but really appreciate any thoughts you bike nuts might have.
Thanks a lot.
Thanks a lot.
