1 - 8 of 8 Posts
done
I'm considering replacing the fork on one of my rides. The stock fork is 371mm from axle to crown. It's tough finding anything to match this. Just about any fork I can find isn't available in stock anywhere.
IRD has a couple forks that I think will work.
One matches the rake (45mm) and tire size + fender dimensions of the current fork. It's 378mm vs 371mm axle to crown, however. How much is that going to throw off my steering geometry? They also have a 43mm rake version. I figure this would help get the trail back to the original design?
The other fork has no fender eyelets. But it does have a A-to-C length of 368mm, so it's a better match in that regard. Would this be a better fit? Rake options are 45 and 43, though I imagine I'd want to stick with the 45 in this case.
Thanks for any help.
The 378 would decrease the HT angle by about .6 degrees. Assuming a 73 degree HT angle (even if it does not the relative changes are the same even if the numbers are not) the stock bike would have 56mm of trail. With a 7mm increase at a rake of 45mm you’d have a new trail of 58, which a 2mm difference is generally not perceptible. Decreasing the rake to 43 would give you 61mm, and that would give you noticeably slower handling. I think you have the idea backwards; you want more rake with an increase in A-C length as more rake results in quicker handling, and 47mm would put you back at 56mm of trail. The other fork at 45 would give a 2mm reduction in trail, 43 would be almost the same as stock.
Hiya,
doing something similar but it's becuase I want to fit a disc to the roadie.
Do you have a link to where you are getting the IRD forks from please ?
Cheers
Michael B
Slow but not so steady
Go for it. If you go from a 371 to 378, you will not know the difference after 3 miles on bike.
I went from 372 to 384. The handling was a little sluggish but forgot about it after a few miles. I kept the rake at 45.
If I had gotten a 50 rake on the 384 Axle to Crown fork, the handling would have matched up perfectly with the 372 A to C/45 rake.
Hi acckids,
Thanks for the feedback. I'm in the process (waiting for the last of the parts) of putting a disc on the road bike, and will be going from 374 to 403mm using a Mosso fork just to see the effect.
If it's too much, will then go to a custom fork from Woundup (bloody expensive, but best option found so far) to get the correct axle-crown length.
Have found one that is 384mm from Traitor, but it weighs 1000g, which is a bit heavy.
TThe Mosso fork was only A$65 delieverd, so is a good starting point.
Cheers
Michael B
1 - 8 of 8 Posts
