1 - 7 of 7 Posts
Hey guys,
I am currently using BB30 adaptors for my ultegera 6800 on my felt f75 Would using a bottom bracket change anything??? I was taking a look at the praxis one but idk
Sent from my SM-G935T using Tapatalk
I put a Wheels MFG. outboard BB on my November BB30 frame Last year. 7000 miles later and still happy. No squeaks, creaks or other issues. My next bike will have a Wheels BB on it from the start.
Hey guys,
What adapters now? The black wheels mfg? If you have no problems with the current setup, I see no reason to change it until you need new bb30 bearings. With no chain, you can give it a good inspection for play and smoothness.
It won't hurt anything to install the new praxis bb30 adapter, but why fix something that is not broken?
Yeah I'm using those adaptors. When I was spining the crank without the chain before the build it sounded decent. I guess I'll use the adaptors till the bearing start creaking. Thanks for the help
'brifter' is f'ing stupid
The bearings won't creak, the adapters will. Clean 'em, grease 'em and put 'em back in. When the bearings wear out they'll click. They may make some funky noises in the frame, mostly clicks.
Sound is only part of the equation, and squeaks and clicks probably won't appear when turning the crank with no load. When you take the chain off you should turn the crank slowly with your fingers near the crank axle. That will all you to feel any binding, grittiness, rumbles, or loosening.
1 - 7 of 7 Posts
