1 - 20 of 31 Posts
(originally posted in the wheel/tire forum with no response)
Got into cycling a couple of years ago. Just bought these wheels from Performance Bike to upgrade my bike.
Easton does not provide any information on how to adjust the bearing preload on the R4 hubs. On their site, all they show is an animated picture with the adjuster rotating back and forth.
Is the adjuster turned with the wheel in place (on the bike) and the skewer locked? How far should the adjuster be turned? How do I know when I have the proper adjustment? Thanks
I'd also like to know how you tell if you have the hubs adjusted properly as I've just got a pair of EA90 SLXs. I reduced my preload on my rear wheel (by a turn) from how they arrived and it seems to have made the wheel roll better - but it's just guesswork.
GdL
I used the following part of Sheldon Brown's advice to adjust my pre-load. Hopefully I'll get out on my bike today to see if it's made a difference.... if someone who knows how to do this thinks there is a better way, please let me know. Thanks
"To check your bearing adjustment, put the wheel into the bike with the quick release just barely tight enough to keep the wheel from falling out. If you are working on the rear wheel, take it out and re-install it so that the chain is not engaging the sprockets.
Try to wiggle the rim back-and-forth between the brake shoes; since the QR isn't tight, there should be a bit of play. If there is, hold the tire so that the valve is at the 3:00 or 9:00 position, then let go of it. On most wheels, the valve is the heaviest part; on wheels that have spoke reflectors, the reflector will be the heaviest part. Whatever is the heaviest part of the wheel, it should cause the wheel to turn and swing back-and-forth like a pendulum, before finally coming to a stop.
Once you have seen how the wheel turns with the quick release loose, try tightening the QR, then check again. If your bearing adjustment is correct, the play will disappear, but the wheel will turn as freely as it did when it was too loose. For very fine tuning of this, you can slightly vary the adjustment of the quick-release skewer, as long as it is good and snug."
Carbon Fiber = Explode!
You guys, the preload adjustment is right on the hub! You can do it with your hands!
Easton has all their maintenance info on their website.
Hi CleavesF
Thanks for the reply - and yes we know that you can adjust the preload without any tools - we just can't find any information to tell us how we know when the hubs are correctly adjusted ... I can't find any info on the Easton site to tell me that. So far it's trial and error - but yes being able to tweak it by hand (as shown on the Easton site) is good - just not so helpful that they don't say how to tell it's correctly adjusted.
Thanks again.
GdL
Thanks for your reply - I have EA90 SLXs too. I think I might have mine a little rattley now - I only have about half a turn on from the minimum setting.... I'll check them again on my next ride and maybe add a bit of pre-load back in. Looks like it's just trial and error.
Thanks again.
GdL
Discussion Starter · #9 ·
Thanks for the advice
Adjusted the preload on both wheels. On the front wheel, when there was slight sideways movement, adjusted preload a touch tighter just so there was no movement. Spun front wheel and just before stopping, the wheel rotated back and forth about four times. Rear wheel was harder. Adjusted it so that after rotation stopped, it just started to rotate backward. Can't wait to ride. (Have at least one foot of snow outside, so it will be awhile).
CleavesF is right on, the adjuster works very much like a headset.
Contrary to Sheldon's article which deals mainly with cup and cone hubs we find it is best to adjust the hubs with the quick release fully tightened.
Similarly to adjusting a headset it is best to start with the adjuster loose so that you can feel some hub play by grabbing the rim and tire and wiggling from side to side.
Gradually turn the preload adjuster clockwise while wiggling the rim / tire to feel for hub play. When you can no longer feel any play in the hub the adjustment is complete.
Also, we have a new version of the preload adjuster for R4 and R4SL hubs. The new adjuster uses a cone wrench for adjustment rather than fingertips. Please feel free to call the service center at 800-347-3901 x5177 for replacement preload adjusters.
If you have adjusters which seem to come loose frequently this new adjuster will resolve that issue.
http://www.eastonbike.com/TECHNICAL/technical_FAQ-wheels.html#13
Look at # 13 in the FAQ.
I start with the adjustment loose and wiggle the wheel back and forth, then tighten up on the adjuster just until the play goes away.
They also have an upgrade for the preload adjustment. The new version you need a 19 mm
cone wrench to Adj.
The new adjuster comes with a rubber o ring in it and keeps it from loosening on it's own.
The old adjuster was too loose and would move while riding.
I would get home and the wheel would have play in it again.
Then I would have re-adjust it again.
a$$hole
has anyone used the new preload adjusters with the o-ring? There TONS of complaints of the preload adjusters coming loose on every ride and having to be readjusted again. I'm wondering if the replacement preload adjusters have resolved the issue?
Also, does anyone know if Easton is shipping out all new wheels built with the replacement adjuster already? Surely the replacement adjuster is now standard on R4 and R4SL hubs?
Can you please tell me more about this new preload adjuster? I have one of the first pairs of the EC90 SL (2009) Clinchers and find it extremely difficult to adjust with my fingers!
Is this replacemnet preload adjuster available world wide? South Africa?
R4 hubs, new preload adjuster
Well guys I have a newer set of EA90 SLX wheels with the new preload adjuster using the 19mm cone wrench. It came with the wheels. I can say that it solves the problem of the adjuster loosening. Now if Easton could learn to build wheels with a quality spoke instead of the crap sapim spokes they now use it would be a great set of wheels. Only put 150 miles on this new set on super smooth road surface. I wiegh 170 I'm 58 years old and already have a broken spoke. The reason I say this is that I'm too old to be a wheel thrasher. I may ride over 20 mph avg speed but I'm not a racer either and don't hammer out of the saddle. I'm down on the gulf coast and no hills to hammer either. First let me say that I am a wheel builder and been doing it for over 30 years. I have wheels out there that have rolled over 20,000 miles with no spoke replacement and needed very little trueing if any. From what I see after removing the spoke that broke is that they are using spokes longer than necessary. The end of the spoke protruded out of the nipple on the back side by 1.5 -2.0 mm. That means on a 12 mm long nipple the threads of the spoke where as tite as they could go against the beginning of the threaded portion of the spoke. Thats where the spoke breaks. They should have have had a 3mm shorter length spoke. This broken spoke was on the rear wheel non drive side and all the spokes were like that on inspection. Now I know this could be related to the way easton builds wheels. They lace and tighten drive side first then bring dish in by using the radial spokes on non drive side to dish. That creates a very tite drive side spoke . So It may be necessary to use that extra length to engage the nipple threads.
So after all that there is still no excuse for the terrible service reliability delivered by this wheel. Its a very nice riding wheel and feels great but does'nt last from what I'm seeing on the net.
I followed Easton's advice and called their support number. I talked to a very helpful lady who sent out a new axle and preload adjuster for my rear-wheel. It was quick and simple much to my surprise.
I'm highly impressed and will look more closely at Easton products in the future because of this good experience.
Hey Drewsky, do you know if this preload bearing replacement is available to anyone? I ask since I am not the original owner of the ea90 aero wheelset though I would love to have this part as I'm not into the stock one. Seems that I can't get the rear bearing adjuster tight enough to take out the play in the wheel without it creating drag on the hub turning my bike into a fixie, i.e. the chain falls off if I stop pedaling.
any info on Easton's CS policy would be helpful... calling them tomorrow morning.
The kind CS never asked. I wouldn't bring it up in the conversation. Make sure they send you both the front and the rear.
The idea behind the bearing preload adjustment is that as the bearings wear, you tighten it. It sounds like you need to replace the bearings. It is super easy and cheap. Easton has a good manual page here. You can order these bearings from a lot of places online.
Well, I called, and they are getting me the newer bearing preload adjusters, but I am being charged. However, its only $3 for the front and $5 for the rear and $3 for shipping. Although I have to call back since their system was down when I called.
Here are the part numbers if anyone is in need:
Front #2014335
Rear #2014347
One more drewsky, not finding much on replacement bearings for the R4 hubs outside of some generic ones on ebay. do you have a source? Also, any special tools required to install the new bearings. I've read about a "drift" needed to install correctly.
I'm a DIY'er, but I'm okay to take it to the lbs if a correct install requires tools I don't have.
thanks.
1 - 20 of 31 Posts
