Ok, as some of you may know I have had some issues with my bikes current setup for bars and stem. First off they were to narrow at 42cm and second the stem was to long and had no rise. I had about a 4" drop from my seat to the tops of my bars. For me with my size it was to much and I felt like I was reaching to far with the 120mm carbon stem bar combo. (Cinelli Ram Jam Carbon Bar stem combo).
So I am in pursuit of a new bar Stem Combo. I picked up a Specialized Roubaix bar that is a 44cm and a Specialized stem that has a bunch of different cams of sort to give you various rises. The rise I will start with first is the largest one at 16 degrees... I wanted to get some input on a few things. Is there a correct angle for the bar to be installed at? What about brake hoods etc? Also how far up the stem should the fork tube come. From what I see I am probably close to an inch between the top of my stem and the for tube. This is more than the Cinelli stem, bar combo.... I haven't taped my bars yet because as I was cutting my cable's for my brakes I boogered up one of the cables because my wire cutter suck and wouldn't make a clean cut. I am going to have to replace the cable now. So with these photo's of before and after how to my angles as far as bar and hood look. Or is this all personal preference?
Before:
After: Now my Seat to top of Bar drop is only 2" and i have a shorter stem with a rise now...
Before:
