I just received a new set of Mavic Allroad Elite Pro UST wheels (2019). After installation, I noticed the rear wheel disc rubbing on the pad in one spot. I swapped out the disc with another that I know is true and it is also rubbing in the same spot. Am I correct in assuming that the axle is likely defective/bent? Could it be something else? Is this a common issue with brand new Mavic wheels?
