I've been using Kafko "Oil Eater" from Kragen. It's water based and works awesome.
* * * Product Description * * *
OIL EATER safely dissolves grease and oil on asphalt or concrete driveways, engines, lawn mowers, tools, ovens and outdoor grills. It's excellent as a pre-wash for dirty clothes and will remove most stains from carpets, floor mats and upholstery. An excellent concentrate for pressure washing and parts cleaning machines. Diluted as directed, Oil Eater saves money. An application and dilution chart is included on the rear label of all packages. The chart is expanded on the one gallon, five gallon, and fifty-five gallon sizes to cover commercial, industrial and utility applications. NON-FLAMMABLE, CONTAINS NO ACIDS, ABRASIVES OR PETROLEUM SOLVENTS. AUTHORIZED BY USDA FOR CLEANING NON-FOOD AREAS. OIL EATER CLEANER/DEGREASER is a water-based, fresh-scented, biodegradable cleaner that effectively replaces flammable or combustible solvent cleaners. It contains no hazardous chlorinated/fluorinated solvents or acidic-type chemicals. OIL EATER'S formulation safely accomplishes the cleaning that previously required solvent or acid cleaners and exposed the user and the environment to the inherent hazards of such chemicals. This unique formula of non-ionic surfactants, emulsifiers, water softeners and other biodegradable ingredients cuts through oily and greasy dirt, encapsulating the oil and dirt into a solution that can easily be rinsed away. OIL EATER CLEANER/DEGREASER has been used successfully by the automotive, machine tool, metal fabricating, micro processing, packaging, professional fabric cleaning and many more industries for production as well as maintenance of their facilities. IT TRULY IS THE ONE NEW CLEANER THAT REPLACES MANY.
