Here's a round-up of some of (but certainly not all) of the best JensonUSA Cyber Monday deals.​
Tis the season for holiday shopping and that means bargain hunting - especially for cycling gear. Here are some Cyber Monday deals from RoadBikeReview partner JensonUSA.
Wilier Zero.7 Dura-Ace
Best JensonUSA Black Friday Deals
The Wilier Zero.7 Frameset 2018 is the lightest bicycle ever produced by Willier-produced with the goal of setting a new design standard for ultra-light racing bikes. Aside from being one of the lightest road frames the Wilier Zero.7 Frameset uses modern cycling technologies such as: cable integration, integrated fork, and better aerodynamic efficiency to produce a bike that performs just good as it looks. The Wilier Zero.7 Frameset 2018 features new construction techniques that have allowed for a reduced volume of the frame tubes by 19%, while still maintaining its lateral stiffness and durability and safety.
Price: Was $6549, now $4800 - save 27%
Hot Deal: Shop Here
Continental Grand Prix 4000S II
The Grand Prix 4000S II is the reference tire for whose standards other companies strive to achieve. The Grand Prix was the first open clincher to enter into the world of road racing and remains to be one of the best to this day. The GP4000S II gives a facelift to this road racing veteran. Continental's legendary Black Chili Compound and Vectran breaker provide extremely high mileage performance and the make the Grand Prix 4000S II an ideal competition or training partner.
Price: Was $75, now $41 - save 44%
Hot Deal: Shop Here
SRAM Red 22 Rim Brake/Shifter
The SRAM RED 22 ErgoDynamic Shifters continue SRAM's philosophy of perfecting the interface between rider and bike. For SRAM's top-shelf RED 22 series, everything was scrutinized, including the transition between handlebar and hoods, the grip texture, finger wrap, and the separate interfaces with both the shifter and brake lever. The result is an extremely comfortable, highly individual fit that makes the shifters feel like a natural extension of the rider.
Price: Was $508, now $250 - save 51%
Hot Deal: Shop Here
Easton EC70 Carbon Seatpost
The Easton EC70 features a forged aluminum head bonded to a full carbon quill, offering an impressive strength-to-weight ratio at a price more people can enjoy. The EC70 carbon seatpost still incorporates the RAD Relief-Area Design and Taper- Wall technology to properly distribute stress along the entire post, making for a lighter and stronger seatpost. Easton has also removed material in critical clamps zones to prevent pinching the carbon which could affect the durability of the post.
Price: Was $150, now $55 - save 63%
Hot Deal: Shop Here
3T Ernova Handlebar
Most riders think handlebars are just handlebars, but they are a lot more than that. A good set of handlebars can increase your riding comfort or they can increase the aerodynamics of your bike. The Ernova Handlebars from 3T offer all-day riding comfort with their large egg-shaped top section. This provides a wider surface for your hands to rest. They feature a 31.8mm handlebar clamp and are clip-on aerobar compatible. So if you like using aerobars while you ride, then these are a perfect choice.
Price: Was $80, now $30 - save 63%
Hot Deal: Shop Here
Bell Stratus Helmet
Built with the same core design principles as the pro-level Zephyr, the all-new Stratus road cycling helmet combines lightweight aero efficiency with cutting-edge comfort technologies. The shape was refined for all-around road performance ventilated for long climbs but still fast for the flats and the all-new Float Fit system offers comfort and security with a streamlined fit and an oversized dial that's easy to adjust with one hand. The Overbrow Ventilation system pulls cool air in through the front and pushes it through an air-channel matrix to reduce overheating. And thanks to the adjustable No-Twist Tri-Glides, the straps stay flat and properly positioned no matter how hard you're hammering.
Price: Was $130, now $66 - save 49%
Hot Deal: Shop Here
Mavic Ksyrium Pro Carbon SL Disc
Mavic's new Ksyrium Pro Carbon Wheels are here to save you weight and improve your efficiency. The 17mm internal rim width increases air volume, and the Griplink/Powerlink tires reduce rolling resistance while maintaining grip. The improved ISM 4D rims reduce drag, allowing the wheels to cut through the air, and the double butted spokes save weight and improve efficiency.
Price: Was $2400, now $1000 - save 58%
Hot Deal: Shop Here
Shimano Dura-Ace Wheelset
The Shimano Dura-Ace WH-R9100-C24 Wheelset receives minor tweaks and improvements on this already reliable line of wheels. It features improved drive rigidity and responsive acceleration thanks to its offset rim and wide flange hubs. The C-24 is the most lightweight clincher wheelset in the Dura Ace 9100 offering, coming in at a feather weight of 1412 it makes itself well at home when the roads tilt upwards. Shimano's lust-worthy 9100 series hubs boast a buttery smooth spin quality based on Shimano's cup and cone design. The cup and cone ball-bearing design is easy to maintain and offers some the best road hub performance around. Ascend with ease and descend with confidence knowing that these wheels offer superior braking performance thanks to the aluminum brake track.
Price: Was $1150, now $830 - save 28%
Hot Deal: Shop Here
Light and Motion Urban 350 Light
As the lightest, brightest, most compact light in its class, the custom engineered reflector optimizes the light to provide a smooth, even beam pattern that precisely focuses the light right where you need it. As a dedicated commuter lamp, Light and Motion recognizes that side lighting is just as vital to safety as head lighting. Side lighting doesn't necessarily enhance rider visibility, but more so enables visibility for drivers to see the rider. The Urban 350 strategically features side lighting to maximize visibility on roadways with a dedicated button to switch the side lights on and off.
Price: Was $50, now $27 - save 46%
Hot Deal: Shop Here
Check out more Cyber Monday deals on JensonUSA.
RoadBikeReview is committed to finding, researching, and recommending the best products. We earn commissions from purchases you make using the retail links in our product reviews. Learn more about how this works.
