1 - 2 of 2 Posts
Endure26
Discussion Starter #1
Posted this on the commuting board - thinking I was posting it here - duh. Anyway...
Anyone know the largest width tire a Bianchi Pista frame/fork will accomodate? Thanks in advance.
__________________
I put IRC "Road Winer" 700-28C tires on a Pista a few weeks ago. The actual width of these tires is 25.7 mm. Tire sidewall-to-frame clearances with these tires are: 4 mm at the chain stays, 9 mm at the seat stays, and 10 mm at the fork blades. Clearance under the fork crown is 6 mm.
Your question is difficult to answer with numbers alone, because nominal tire sizes often are way off from their actual measurements. Looking at my measurements above, I'd say that a 700-32 tire should fit the Pista if doesn't run too large.
I'm also interested in fitting even larger tires to the Pista. Does anyone have a size AND brand/model recommendation?
1 - 2 of 2 Posts
