1 - 6 of 6 Posts
Ok... So I've already searched the internet fairly extensively.. I'm looking for a bib tight that I will utilize skiing.. they need: front panel zipper for easy access, no pad or insert, no ankle zips. Anyone out there using a decent bib with these specs..??
I have seen Gore's bibs, but their inseams are so long... I'm a 32" and don't want a coupla inches bunched up...
Anyway.. thanks for any suggestions..
irony intended
Assos is another brand, and has at least two models that fit this requirement.
You couldn't have searched the interwebs all that hard....
Thanks guys... completely missed Rapha.. Assos I knew about, but is very pricey.. not that Rapha isn't... If nothing else I could also find front zip/no ankle zips and remove the pad/insert.. Just thought someone might be rocking a 'compression' bib/tight that fit the bill... and yeah I did spend basically an entire evening searching the web... Wiggle came up with the most brands I could search thru.. but many incorporate ankle zips.. and that is a deal killer...
1 - 6 of 6 Posts
