1 - 20 of 34 Posts
I'm moving towing my Subaru hatchback on a car carrier behind a 16' moving truck. I do have a bike rack for the hatch but I'll probably be driving through some rainy weather and getting the bicycle all wet and muddy doesn't appeal to me. Could I lay down the rear seats, take off the front wheel,and just lay the bike down in the trunk cushioned with a blanket or two? The car has got enough clearance.
Putting the bicycle in the truck does not seem like a good idea unless I pack it in a box, and for that I would have to probably buy the box, hire the LBS to pack it. All which is about 70 miles round trip and figure about $50-70 not including gas and time back and forth. I'm busy enough packing as is.
Any negatives to this approach I've neglected to consider, or things I can do to protect the bike?
Doesn't like subtitles
I don't see a problem. Ive carried bikes around in backs of cars (including a Suby) all the time.
No negatives. Preferred over external rack anytime. Just make sure the bike isn't rubbing up against anything. Cover the greasy drivetrain with a old sheet, towel, or large garbage bag.
Sent from my Nexus 7 using Tapatalk
Banned Sock Puppet
What negatives could there possibly be in doing this? I transport my bike in a smaller hatchback than this all the time. Remove front wheel and put it in a safe place. Just be sure to place the bike drivetrain side up so derailleur doesn't get bent. You may want to cover it with a tarp just to keep it out of sight-out of mind to would-be thieves.
I use the 55 gal 3m garbage bags to cover the back end of the bike to the crankset and place the derailuer on top,, no worries..
You are aware of course, that as a full time AWD vehicle a Subaru cannot be towed on 2 wheels, Needs a flatbed trailer.
change out the tubes when you arrive at your destination and all should be fine.
Russian Troll Farmer
Yes, very important. You will destroy your transmission (or more likely the viscous couplings to the rear wheels) if you try to pull it with a 2 wheel dolly.
Banned Sock Puppet
This is true. An full time AWD vehicle (all Subarus) must be towed on a flatbed. Towing on two wheels will wreck the transfer case and viscous coupler.
Pathlete and Pedalphile
If its a carbon bike just make sure it doesn't get too hot in the car. Everyone knows that carbon bikes are known to assplode in hot cars.
I know this is off-topic, can you remove the driveshaft from front to rear and tow on a dolly?
If you don't want to tow it with a flat bed, you can tow it all 4 on the ground so that all wheels are spinning at the same rate.
Of course you can. But with today's awd system, it'll likely be much more involved in decoupling the drivetrain. Towing on all four can introduce tracking issues if vehicle's frontend is out of alignment, but I suspect getting this verified won't be high on one's moving to do list.
Bianchi Nuovo Alloro, Lemond Etape
two wheel dolly is cheaper but flatbed is really not that much more difficult, and in my opinion is easier to maneuver.
I remember years ago when someone posted a thread asking where he could find a suitable cardboard box to use to ship a fork for warranty work.
Next to that thread, this "can I put my bike in my car" thread is, well, I guess I shouldn't say.
1 - 20 of 34 Posts
