I guess I don't see it this way. If Sky had known Nibali's 5/20/60 min mmp in this years Giro, would it have changed the way they raced the Giro? If Astana had known Wiggins power would he have dropped out faster?
I guess I can understand not publishing daily numbers until after a GT is over, but publishing pre tour tests and numbers after the race is over seems innocuous
Would you like to know your opponents' power numbers?
Let's put away GC and think back to the time when the HTC train would run down a break and give Cavendish the perfect leadout. They had it down to a science...almost!
There were times when the breakaway stayed away. Would knowing the power numbers of all of the riders in the break play into the tactics of running them down?
A related issue is this: There are complaints about race radios and how they make races less exciting. There are complaints about team Sky and how their tactics make races less exciting. If everyone knew everyone else's power, would that make races more or less exciting?
The real reason not to deal with actual power numbers seems to be validating calibration of the PM used. Its easy enough to change to offset of your SRM/whatever and give a lower/higher number than reality.
I've brought this up in the past. If athletes are using countermeasures to defeat doping tests there is no reason to think their power numbers the athletes give Bike Pure (or whatever) will be 100% accurate. If they employ physicians to help them around medical tests, why not employ an IT guy to doctor the SRM numbers?
Let's not fool ourselves into believing that releasing the power numbers is going to solve the doping problem.
On the other hand, I think cycling as a while could modernize and become a little more exciting. I would like to see live gopro feeds from riders' bikes during races with dashboard data, RPM, current speed, power, etc. It would be great to see a helicopter view and then cut to the view from Sagan's handbars!
