saccycling said:
How often should I take my bike for a tune up ? I got 9500 miles on my bike now. I change the cassette and change myself about every 4000 miles, I have a chain checker. I had my rear wheel trued at 5000 miles after hitting a big pot hole. I was thinking maybe I should have a mechanic look my bike over. How often do you get your bike tuned up or looked over ?
Just take it in whenever it stops working properly. Like if your gears don't shift or start skipping when you hit the shift button.
While those problems are things you can easily fix yourself, a good (!) shop mechanic can diagnose much bigger problems before they happen. For example, a good one can tell you your bearings are dry and need to be overhauled... before opening up the hub. This could save you a new set of wheels next year!
If it stops shifting properly, chances are (if it was done right) that it has had enough time for bearings to dry out, bb cups/bolts to come loose... etc...
Beware though, good shops/mechanics (or sometimes I've seen ONE good mechanic in a shop full of idiots- just request that the good one does it) are hard to find. Look for experience. Check out the "family" oriented shops- ones that have people from college student commuters, to high end racers coming through. The mechanic that has been working in the "family" shop for a few years has seen bikes that have been through hell and back, over multiple tuneups, through numerous problems. If they can get a 10 year old, bottom of the line Trek working like an Ultegra10 bike, then imagine what they could do to a DA10 bike.
I'm not saying don't learn to fix things yourself, it really helps when you're out with your buddies and someone's der goes into their rear wheel, you'll get the free beer when you get his bike limping home.
