1 - 9 of 9 Posts
What are peoples opinions on saddles and bar tape? Which goes best with a celeste frame, white or black?
Bicycle frame Bicycle tire Bicycle wheel Tire Wheel
White is better. Wear gloves with white palms to avoid transferring dyes into the bar tape.
Sent from my XT1565 using Tapatalk
I go with White tape, White saddle on the majority of my bikes and at least white tape on the others. Most bikes already have a ton of black on them between the cockpit, seatpost, wheels, groupo and the logo's. I like to bring the white as an accent color. The white for me is the traditional PRO look that worked for Coppi, Merckx etc, before the Bennotto colored tape of the '80's. I use Fizik and have no problem keeping it clean. Change the tape once in early spring and then in fall. Cheap way to make the bike feel new. My .02
Of those, I personally prefer the black because of the black lettering.
If you had white lettering, or at least some other strong white accents on the frame, then I'd say go all out and use a white seat, white tape, and definitely include white cable housings.
Bianchi-Campagnolo
Black saddle, Celeste tape, or Celeste/Celeste, because you can never ever have too much Celeste.
White if the bike is predominately white.
In this case the black accent is strong i'd go with black...why not mix it up and see what you like?
1 - 9 of 9 Posts
