Great idea! Got the pump, and it fits exactly like you said it would! Thanks!bc165 said:and the frame and it works beautifully - this is how this pump is intended to be mounted, no genius on my part. The mounting bracket is just the right thickness for spacing, and the black and grey carbon pump matches my Roubiax Comp and Tacx cage perfectly. It's a good little pump too, but I can't imagine getting 100 lbs out of it.
However, for this to work - very important - I had to get longer mounting bolts from my lbs... standard size wouldn't reach.
I plan on adding a 2nd water cage and this seems like a great way to kill 2 birds (cage and pump) with 1 stone.bc165 said:and the frame and it works beautifully - this is how this pump is intended to be mounted, no genius on my part. The mounting bracket is just the right thickness for spacing, and the black and grey carbon pump matches my Roubiax Comp and Tacx cage perfectly. It's a good little pump too, but I can't imagine getting 100 lbs out of it.
I used it once, it worked but I had to pump for a long time to get it up to about 120lbs. It's better than the other small handpumps I've used, plus it looks great!upstateSC-rider said:I plan on adding a 2nd water cage and this seems like a great way to kill 2 birds (cage and pump) with 1 stone.
Does everyone like this pump?
Lou.
