1 - 4 of 4 Posts
Went to change my bottle holder last night and when I tried to screw in the new holder the screw just pushed in. Does anyone know how to fix this? Also what is the thread? I am assuming I will need to re tap the hole and replace the thread with a helicoil?
Big is relative
It would depend on if your frame had brazeons or inserts. The helicoil sounds like a good solution for a braze on. I work with alot of frabrications and have not had great success using helicoils on aluminum. Sometimes it works.
Solution
I am a mechanic by trade (cars not bikes) and I have used a vey small amount of JB Weld on a toothpick to fill the area in a recessed threaded hole, let it dry (cure) drill a pilot hole JUST UNDER the size of the bolt and tap as normal. JB Weld holds sleeves in race car engines under tremendous tempuratures and loads and I know whole-heartedly it will hold a bolt securing a bottle/cage. Try it. Good luck. Mike
Thanks man
Great idea, I'll give it a try.
1 - 4 of 4 Posts
