I'm thinking about having a steel frame built up (using XCr tubings).
And I read this article below explaining the different types of bottom brackets.Bottom Bracket Standards - Slowtwitch.com
Basically, what the article is saying that wider bottom brackets using bigger diameter spindle make for a stiffer frame because manufacturer can pack more structural material around the bottom bracket area, therefore reinforcing the bb and hence making a stiff frame overall.
I'm thinking, most of these frames using these press-fit are also carbon frames, and it's easier to layer up more carbon material around the bb area. But for a metal frame, it's not like you can "layer up" more metal material around the bb area. Metal tubings come in certain wall thickness, and that's that.
I can't see how a BB90 would benefit much on a metal frame when it comes to stiffening up the bb area. Probably a 68mm BSA bottem bracket tube with thicker wall will make for a stiffer bb. However, I can possibly see that a BB30 can make for a stiffer bb and stiffer frame (on a metal frame) if the downtube is also oversized to take advantage of the BB30 bigger diameter (spindle diameter). But again, I gotta ask, how much stiffer? Probably not anything significant.
Anyway, my question is, i'm planning on having an XCr frame built for me, and I'm 130 lbs (nothing like a brute), should I just stick with 68mm BSA type bb? I can also have it built with BB30, but from all the "my BB30 is creaking" posts that pop up every few weeks, I'm kinda cringing at the BB30 option.
thoughts??
thoughts??
