Enoch562 said:
I was hoping these would go front or rear. Seems I can't find both at the same place for a good price, plenty of rears, no fronts. Just doesn't make much sense to not have both...
Front brakes outsell rears because they get crash damaged much more often.
If you're considering a brake where the front and rear are identical other than brake bolt length, and your fork is drilled for flush mount allen nut, you can use a rear in the front and compensate with a longer mounting nut.
Note - there's a limit to the length of nuts available, so measure your fork's crown thickness, and check for nut availability before buying the brake.
