1 - 7 of 7 Posts
Currently using the yellow SwissStop pads that came with the brakes. These are compatible with either carbon or aluminum rims and performance is OK on alum but I was wondering if I would get better performance with other pads as I will be using alum rims only on this bike. I understand that any 2000 or newer campy compatible pads will fit.
does anyone know if the yellow pads that come with the Zero's are lighter than most pads, or are they pretty standard. i have had mine for about a year now and am looking to replace. it sounds like the green are the way to go. i am using mine of a set of Ksyrium Premiums...
Same weight. If you don't ride in really wet condtions, Swiss Stop Blacks are great. Green is for really wet weather and ceramic rims.
1 - 7 of 7 Posts
