1 - 7 of 7 Posts
Riding towards Delmarva.
Building up my Steamroller with a Surly flip/flop hub. I plan on riding this thing in the mountains so the ss with brake will be used.
I have a spare drop bar and a knock-off Albatross (not a moustache).
The Albatross is being pulled from an old Schwinn Mixte. It comes straight across from the stem, then pulls back a little, so you can ride with your hands straight on both sides of the stem, I like this position since I climb and do double centuries.....
anyway...
What are my brake options for the front? For the drop bar I was thinking simple brake levers, with the rear lever having no cable. Is there a front lever/hood where the cable can be routed under the bar tape?
And for the Albatross bar, what single brake lever can i pair with this, on the end of the bar, not the middle? I don't know if this set-up will be 'the one', so I dont' want to spend a ton on this lever. Can this lever be routed under the bar tape as well?
There are lots of options. Pretty much all the "plain" (i.e., with out integrated shifters) levers made now have cable routing under the tape. It was called "aero" when they came out, and we though they were pretty cool.
Price ranges run from way cheap, to not-so-cheap
http://www.lickbike.com/sectionsublist.aspx?SECTION='0007'&SUBSECTION='150'&SECTIONNAME='Brakes'&SUBSECTIONNAME='LEVERS'
Roadfix,
On that moustache, where are your hands "most" of the time? What scares me about a moustache, I "like" the back of my Nitto Noodles on my road bike, both sides of the stem. I instinctively reach for that position and the moustache doesn't really have that option, I think.
hello
RedRex said:
Roadfix,
That's one reason I don't use these bars anymore. I have noodles on my tour bike and like the bar tops as well.
Anyway I run bullhorns on my Steamroller now with a cross lever activating the front brake.
Well there you go. :)
I have bullhorns on my TT bike and certainly don't find myself reaching down to those, choosing to stay in aero. Of course the head tube on my TT bike is crazy low, so there could be more to me 'not liking' the bullhorns than just, the bullhorns.
I'll try the Albatros, as planned. I have a "fake" Albatross on an old Schwinn mixtie that I may try first with one cheap lever. If I don't like it I suppose a drop bar it is.
1 - 7 of 7 Posts
