1 - 6 of 6 Posts
So the right side, rear, shifter broke. the shifters are from 2010 I think. 15-25k miles on them, dunno don't really track that.
Should I have both replaced? Is there much difference with the sram red vs the force 10? I will pay the LBS to do it.
Thanks
:cryin:
I would replace just the right shifter.
My right shimano 6600 shifter lasted about 45,000 miles before its innards failed. The left (front) shifter sees a lot less action and continues to function fine after 55,000 miles.
Banned Sock Puppet
No reason to replace a shifter that isn't broken. As The Moontrane said, the left shifter doesn't see anywhere near as much use as the right. Your left shifter will probably outlive your replacement right.
Are you sure it's broken? If it just quit working properly, it may only need a sluice out with WD 40 or some other solvent to wash out the junk and gunk, then a re-lube with oil. Try that before you pronounce the death sentence.
Forever a Student
I'd bring it back to the shop as stated, but I'd do so asking them to either fix it or have it replaced under warranty/good will. Sram has a history of broken shifters, they know it, they're really good about it. So good about it they routinely replace shifters outside of their warranty coverage because they know it's a design issue. At least worth a shot, you might be pleasantly surprised at the outcome.
Thanks all, I will ask at the shop. It is definitely broken.
1 - 6 of 6 Posts
