Is there a good brush to use to apply tubular glue? I got one from Target but it seems to be done after one use. The end of the brush is all glued together.
Tooth brushes are cheap and as stevesbike said the acid flux brushes are even cheaper. All you need is some aromatic solvent (some paint thinners) to soak and clean the brush after your glue job. At $0.25 for an acid flux (soldering paste) brush they are pretty much a throwaway item.Is there a good brush to use to apply tubular glue? I got one from Target but it seems to be done after one use. The end of the brush is all glued together.
winner!what's wrong with your little finger??....after you clean it, you can use it over and over again. It can even be used to pick your nose.
And if you leave the glue on it, those pesky boogers don't stand a chance.What's wrong with your little finger??....After you clean it, you can use it over and over again. It can even be used to pick your nose.
